atlantalexussc400 Posted August 24, 2007 Share Posted August 24, 2007 Hello, I bought this "performance chip" on ebay that turned out to be just a resistor. They claim that it improves acceleration. They say that I should connect it to the IAT sensor. I can't even locate the IAT sensor. Anyone know where it is? Anyone know if it is a good idea to add this resistor to the sensor? Thanks, Sam Quote Link to comment Share on other sites More sharing options...
seanysut Posted November 14, 2007 Share Posted November 14, 2007 Hey, I actually have the same question and was wondering if you found out where the IAT sensor is located,how to install it or if its even safe to do? I bought the same performance chip off e-bay. Thanks, Sean Quote Link to comment Share on other sites More sharing options...
SKperformance Posted November 15, 2007 Share Posted November 15, 2007 The iat they refer to is the MAF signal. It will not do anything to a toyota for more than 5 minutes. The reason why toyotas are so reliable is because the ecu's responds to changes and makes new base lines . So it will work for a couple minutes and then revert back to normal again. Quote Link to comment Share on other sites More sharing options...
Rome08 Posted February 15, 2008 Share Posted February 15, 2008 So where is the MAF sensor because i bought the same resistor and would like to try it. And they have a full refund gauratnee so even if it fails ill jsut return it. Quote Link to comment Share on other sites More sharing options...
