LexChamp Posted August 17, 2007 Share Posted August 17, 2007 95 LS I removed my Nakamichi Amp because I am hoping to be replacing it soon. I noticed after I removed the AMP there water right under the AMP and near the plugs, it also did not smell all that good down there . I've had the car over 4 months and I think it’s fair to say that that water has not been there for that period of time. It has to be getting down there from somewhere, definitely not from inside the car. It has to be coming from under the car, where? I don’t know. Does anyone have any idea where it may be coming from? Or what I can do to fix it. I usually take the car to the high pressure wash. UHHHMM I am planning on changing the Amp but what good is it if I replace the AMP and it gets wet again. Last question. Does an AMP from a 96 LS fit a 95 LS? A 96 LS AMP that I seen has the following numbers on the back. It says Toyota 86280-50150 Not sure if this is serial # QD 033302 and it says pioneer Electronics parts The 95 LS AMP has the following #s: 86280-50160 serial # 06917 it also has B338ULOA Nakamichi Corporation. Does it fit on the 95 LS? A thousand thanks. Quote Link to comment Share on other sites More sharing options...
