tspotter Posted September 5, 2003 Share Posted September 5, 2003 I have a 95 ls400 w/ 85k. Whenever I take my foot abruptly off of the gas pedal while at any speed, the transmission jerks violently. It has been recently serviced (T-tech) but the problem did not go away. The NHTSA shows a similar complaint on their website with no resolution and it refers to a problem with the ECU cutting out momentarily. Help! Quote Link to comment Share on other sites More sharing options...
VMF Posted September 6, 2003 Share Posted September 6, 2003 i have the same problem, and what i notices is if you let the engine heat up to the normal temperature and then put it into gear you will not have this problem. but if u will put it into D on a cold engine you will have it even when the engine is hot Quote Link to comment Share on other sites More sharing options...
tspotter Posted September 7, 2003 Author Share Posted September 7, 2003 Yeah, I did notice that the other day. Driving to the highway it was pretty bad but after a good highway run the problem seemed better. The Lexus dealer want's $89 to test and see if the tranny has any stored codes. I think that unless he drives it with the scan tool attached during the occurrence he wont find anything. pretty annoying. Quote Link to comment Share on other sites More sharing options...
