Disconnecting Rear Brake Light
I recently had a spoiler installed on my GS. It has the LED brake light but my original rear-window brake light also comes on when I brake. Not only is this overkill, but it takes away from the look of the LEDs. How do I go about disconnecting the rear-window brake light?
there is a plug under the deck like where you can see the subwoofer. it is the one not connected to the sub obviously that is for the sub. some cars have the plug under the panel on top of the deck. which you will have to remove the seats and pull up the deck to access it.
this site has some how to diy with pics for removing the rear seats and deck.
http://bananags.grantham-international.com/
hope this helps
hope this helps
Thanks a lot. I give it a shot this weekend.
