JerWong Posted September 4, 2003 Share Posted September 4, 2003 Hey thanks everybody for the great advice. i have another question. since i should purchase new tires due to abnormal wear on my old ones.. which ones should i get? i have a 2001 GS430 and it is running on the 17" rims. the tire is 235mm wide. which tires are recommended? thanks for posting! B) Quote Link to comment Share on other sites More sharing options...
Rush48 Posted September 5, 2003 Share Posted September 5, 2003 I have same wheels as you (17 inch factory). I use, and love, Continental Extreme Contact tires. They are excellent in all weather, have great ratings, and are very inexpensive. Go to tirerack.com and look at the wet/dry/snow ratings versus other brands....then look at the price!!! Good luck! Quote Link to comment Share on other sites More sharing options...
sternern Posted September 6, 2003 Share Posted September 6, 2003 The Kumo's and Falken's drive nice and are pretty quiet. They are pretty inexpensive as well. Although you wont get the same deal, I had mine mounted and balanced for $400. Make sure you get the car aligned after you get the new tires. If your alignment is off badly, you could ruin those new tires within 50 miles. Find a good tire shop to get you tires, and then drive it over directly to the Lexus dealer for an alignment. From what I hear, the alignment should be done at least 1 time a year. Its also possible that your rim is bent and that they are out of balance. When getting the new tires, make sure they have a high speed balance machine. On my rims, I got Falken ZIEX- ZE512 235/45Z-R17's. They ride nice but not as quiet as the stock brand. Your tread design and profile are what determines your noise and comfort level. I posted that from a previous thread, look at tirerack.com. They have some good info even if you dont buy from them. I would recommend to keep the tire size the same. You might consider going to a 50 series tire if the road noise is bothering you. Good luck. Quote Link to comment Share on other sites More sharing options...
