ri55 Posted July 17, 2007 Share Posted July 17, 2007 Hi. I have an 07 IS250 with NAV. I am having a problem with the key less entry and key less lock system. When I try to lock the car by pressing the black button on the door handle the car will not lock and instead makes a long beeping sound. When I walk up to the car to unlock it by using the doorhandles sensor with the key in my pocket the car will not unlock. This happened to me when I first got the car in April but it started working fine in about a day. Now it is happening again. It started yesterday. I can't think of anything that can be causing this. Does anyone have a possible solution for this or is experiencing the same problem? All comments are welcome. Thanks. Quote Link to comment Share on other sites More sharing options...
tex2670 Posted July 17, 2007 Share Posted July 17, 2007 Hi. I have an 07 IS250 with NAV. I am having a problem with the key less entry and key less lock system. When I try to lock the car by pressing the black button on the door handle the car will not lock and instead makes a long beeping sound. When I walk up to the car to unlock it by using the doorhandles sensor with the key in my pocket the car will not unlock. This happened to me when I first got the car in April but it started working fine in about a day. Now it is happening again. It started yesterday. I can't think of anything that can be causing this. Does anyone have a possible solution for this or is experiencing the same problem? All comments are welcome. Thanks. where is your 2nd key? could it be in the car or trunk? the car wont lock if the key is inside. Quote Link to comment Share on other sites More sharing options...
xerxes717 Posted July 17, 2007 Share Posted July 17, 2007 Hi. I have an 07 IS250 with NAV. I am having a problem with the key less entry and key less lock system. When I try to lock the car by pressing the black button on the door handle the car will not lock and instead makes a long beeping sound. When I walk up to the car to unlock it by using the doorhandles sensor with the key in my pocket the car will not unlock. This happened to me when I first got the car in April but it started working fine in about a day. Now it is happening again. It started yesterday. I can't think of anything that can be causing this. Does anyone have a possible solution for this or is experiencing the same problem? All comments are welcome. Thanks. where is your 2nd key? could it be in the car or trunk? the car wont lock if the key is inside. ^^ What he said. This typically happens when the 2nd key is in the car. Quote Link to comment Share on other sites More sharing options...
ri55 Posted July 17, 2007 Author Share Posted July 17, 2007 Your absolutely right. I just so happen to be carrying a bag with my 2nd key inside the car. AMAZING. Thanks for the help. Problem Solved!! Quote Link to comment Share on other sites More sharing options...
xerxes717 Posted July 17, 2007 Share Posted July 17, 2007 Your absolutely right. I just so happen to be carrying a bag with my 2nd key inside the car. AMAZING. Thanks for the help. Problem Solved!! Quote Link to comment Share on other sites More sharing options...
