Power Window Problem
2004_330er
I changed the battery and now the auto windows don't work. The driver side window works manually (no auto function) but I cannot operate the other windows from that position. I can operate them manually from the individual seat positions. Any solution. Sounds like a programming problem due to the break in power, but how to fix?
I found the solution. All windows from all seat positions half way down then all the way up, hold one second. Now they are reset and they work perfectly from the driver's seat! The sunroof also needs resetting after a battery change. All makes sense, I guess, but hard to find in the manual.
  • 1 year later...
