shoozboomer Posted July 5, 2007 Share Posted July 5, 2007 Three days ago, I had a hitch intalled on my RX. The work was done at a local truck speciallty store that goes excellent (not cheap) work. Today, after a days worth of shopping and getting in and out of the truck, my hatch doesn not work. I have tried the remote and the manual (key) method to unclock the hatch. When the hatch is in the locked position the handle feels normal (loose). When I unlock it, it feels like somthing is stuck. I have removed the rear carpet cover and examined the locking mechanisim, it all looks good. Does anyone have a diagram of the rear-hatch lock? Is there an Emergency hatch opening procedure available? I'm locked in the trunk and cant get out!!! RBL> Quote Link to comment Share on other sites More sharing options...
sandrew3 Posted August 19, 2007 Share Posted August 19, 2007 Three days ago, I had a hitch intalled on my RX. The work was done at a local truck speciallty store that goes excellent (not cheap) work. Today, after a days worth of shopping and getting in and out of the truck, my hatch doesn not work.I have tried the remote and the manual (key) method to unclock the hatch. When the hatch is in the locked position the handle feels normal (loose). When I unlock it, it feels like somthing is stuck. I have removed the rear carpet cover and examined the locking mechanisim, it all looks good. Does anyone have a diagram of the rear-hatch lock? Is there an Emergency hatch opening procedure available? I'm locked in the trunk and cant get out!!! RBL> I have the same problem has any one resonded to your question? Quote Link to comment Share on other sites More sharing options...
carguy07 Posted August 19, 2007 Share Posted August 19, 2007 Three days ago, I had a hitch intalled on my RX. The work was done at a local truck speciallty store that goes excellent (not cheap) work. Today, after a days worth of shopping and getting in and out of the truck, my hatch doesn not work.I have tried the remote and the manual (key) method to unclock the hatch. When the hatch is in the locked position the handle feels normal (loose). When I unlock it, it feels like somthing is stuck. I have removed the rear carpet cover and examined the locking mechanisim, it all looks good. Does anyone have a diagram of the rear-hatch lock? Is there an Emergency hatch opening procedure available? I'm locked in the trunk and cant get out!!! RBL> I have the same problem has any one resonded to your question? Mine seems to have lost the spring in the release that you pull on to unlatch it. I have to push the lever back after I open it or it will not work the next time. May have nothing to do with your problem, but worth a try. Quote Link to comment Share on other sites More sharing options...
shoozboomer Posted August 24, 2007 Author Share Posted August 24, 2007 Three days ago, I had a hitch intalled on my RX. The work was done at a local truck speciallty store that goes excellent (not cheap) work. Today, after a days worth of shopping and getting in and out of the truck, my hatch doesn not work.I have tried the remote and the manual (key) method to unclock the hatch. When the hatch is in the locked position the handle feels normal (loose). When I unlock it, it feels like somthing is stuck. I have removed the rear carpet cover and examined the locking mechanisim, it all looks good. Does anyone have a diagram of the rear-hatch lock? Is there an Emergency hatch opening procedure available? I'm locked in the trunk and cant get out!!! RBL> I have the same problem has any one resonded to your question? Mine seems to have lost the spring in the release that you pull on to unlatch it. I have to push the lever back after I open it or it will not work the next time. May have nothing to do with your problem, but worth a try. $169. dealer part (new latch) ... Problem fixed my by local shop. Dealer wanted $300. Good luck Quote Link to comment Share on other sites More sharing options...
