Entry Lighting Adjustment?
Hi guys, I am new here and thanks for all the info. Just purchased a 06 GS430 and love the car. I read in the manual you can adjust the length of time the entry lighting stays on, it says consult your dealer, anyone know how to do this? Also I have M/L system it does not seem to read the title and info on CD's any thoughts?
Thanks,
Mick
Are you sure it doesnt read the name...press the audio button on the nav screen and look it should be there. Also it might be because you are playing a burnt disc. If you get a real CD it will probably pull up the right information. If all else fails bring it to the dealer...you are under factory warranty :cheers:
Hope that helps
  • 3 weeks later...
On the Lexus Site for owners, they have a .pdf fle for identifying the settings that you can personalize. The small print does "the customized features must be programmed by your Lexus dealer".
Below is the link to the .pdf ... You have to register, but it's quick and easy.
Lexus Personalized Settings
If you do have them change the settings, let us know how it went.
wade
