John_LS400 Posted June 27, 2007 Share Posted June 27, 2007 Hi Everyone, I'm new here and first post, I need all help to solve ac no cool air look like only the fan blower. Thx Quote Link to comment Share on other sites More sharing options...
flanker271 Posted June 27, 2007 Share Posted June 27, 2007 Hi and welcome to the club. Add dye to your system and test for leaks......you need to be more specific on your problem, as it could be a bunch of things. Quote Link to comment Share on other sites More sharing options...
UCF3 Posted June 27, 2007 Share Posted June 27, 2007 Also when was the last time you did a coolant flush? Quote Link to comment Share on other sites More sharing options...
LexChamp Posted July 5, 2007 Share Posted July 5, 2007 Also when was the last time you did a coolant flush? I've had problems with my AC. I bougt the car about 2 months ago. I am sure the it has not been flushed in a while. What efffects does it have on the AC if the car has not been flushed in a while. Quote Link to comment Share on other sites More sharing options...
wwest Posted July 5, 2007 Share Posted July 5, 2007 Also when was the last time you did a coolant flush? I've had problems with my AC. I bougt the car about 2 months ago. I am sure the it has not been flushed in a while. What efffects does it have on the AC if the car has not been flushed in a while. NONE! Unless the engine coolant is overtemp and even then it's more likely to be overtemp from failure of one, two or all forced air cooling. Quote Link to comment Share on other sites More sharing options...
