okioki Posted June 26, 2007 Share Posted June 26, 2007 hello all, do you have any similar experience like me? I have 2006 sc430 and in low speeds -parking etc. I hear terrible sounds when turning my car?? sounds are coming from front of car, turning left or right . like a clunks not bells. any ideas?? Quote Link to comment Share on other sites More sharing options...
2970wj Posted April 3, 2008 Share Posted April 3, 2008 hello all, do you have any similar experience like me? I have 2006 sc430 and in low speeds -parking etc. I hear terrible sounds when turning my car?? sounds are coming from front of car, turning left or right . like a clunks not bells. any ideas?? My wife is complaining of the same issue....did you ever get it figured out? Quote Link to comment Share on other sites More sharing options...
waterpolo820 Posted April 7, 2008 Share Posted April 7, 2008 I believe what you guys are talking about is the CV boot and joints. With my acura I had a CV boot tear and the grease inside that lubs the joint went out/dried up, but I caught it before the clunking started. So there is nothing to lub the joint and thus leaving you with the clunking noise that you are describing. Sadly for you two the clunking means more than just a ripped boot, the joints are grinding and are now bad. So you need to replace the boots and the joints. For my acura it cost me about $500 for one side full replacement. I have yet to replace them on my SC 430. Also I would consider getting that fixed right away, because it could lead to further problems and eventually you won't be able to steer. Quote Link to comment Share on other sites More sharing options...
TonyNZ Posted February 26, 2009 Share Posted February 26, 2009 I believe what you guys are talking about is the CV boot and joints. With my acura I had a CV boot tear and the grease inside that lubs the joint went out/dried up, but I caught it before the clunking started. So there is nothing to lub the joint and thus leaving you with the clunking noise that you are describing. Sadly for you two the clunking means more than just a ripped boot, the joints are grinding and are now bad. So you need to replace the boots and the joints. For my acura it cost me about $500 for one side full replacement. I have yet to replace them on my SC 430. Also I would consider getting that fixed right away, because it could lead to further problems and eventually you won't be able to steer. I don't think it would be CV joints as the car is rear wheel drive. Are you running the stock wheels? Quote Link to comment Share on other sites More sharing options...
krafter324 Posted April 3, 2009 Share Posted April 3, 2009 My car does the same things. Does it mostly when it's been sitting for a bit but not quite sure what it is since the car has only 33K miles on it and has never even been driven in the rain. Wouldn't think it's anything major..... at least I hope. Quote Link to comment Share on other sites More sharing options...
mdames Posted April 15, 2009 Share Posted April 15, 2009 My 2003 did the same thing. It turned out to be the front brake calipers. My dealership made some adjustments to them (not sure what they did) and that solved the problem. Quote Link to comment Share on other sites More sharing options...
pjer Posted April 16, 2010 Share Posted April 16, 2010 hello all, do you have any similar experience like me? I have 2006 sc430 and in low speeds -parking etc. I hear terrible sounds when turning my car?? sounds are coming from front of car, turning left or right . like a clunks not bells. any ideas?? My wife is complaining of the same issue....did you ever get it figured out? Quote Link to comment Share on other sites More sharing options...
pablopicaso Posted April 16, 2010 Share Posted April 16, 2010 hello all, do you have any similar experience like me? I have 2006 sc430 and in low speeds -parking etc. I hear terrible sounds when turning my car?? sounds are coming from front of car, turning left or right . like a clunks not bells. any ideas?? I have a 2006 SC also and I occasionally do hear a clicking sound that seems to come from front end. I hear it sometimes when I switch from rev. to fwd movement, sometimes on a turn but i Only hear it once then wont hear it for a while. I've tried (sharp) turning the car in both directions at slow speeds but dont here anything like that so I dont worry about it. Do you hear repeated cluncks during the turn? If so would have it check out as it may still be a joint problem. Quote Link to comment Share on other sites More sharing options...
okay3wire Posted June 11, 2010 Share Posted June 11, 2010 I have a 2004 with 18,000 miles and I hear the same thing when reversing at low speeds. I will need to check out my brake calipers. Quote Link to comment Share on other sites More sharing options...
Bly Posted February 1, 2012 Share Posted February 1, 2012 There are four bolt up high in the wheel wells on both sides. I had the same problem and my mechanic put an impact drill and a torque extension on them (from underneath). Tightened them up and noise was gone. It seems they have to be very tight. Of course also make sure the rest of the front end is right. Quote Link to comment Share on other sites More sharing options...
peter townsville Posted January 20, 2013 Share Posted January 20, 2013 I had the same problem on my 2005 sc430. It was the clips attached to the brake pads. The sc430 uses a brake pad clip mechanism that I haven't seen before. The stock pads make this noise by moving forwards and backwards when you reverse and then drive forward. I replaced mine with Bendix ceramic pads. problem solved Quote Link to comment Share on other sites More sharing options...
