nlexclusives Posted June 24, 2007 Posted June 24, 2007 Can I add amp and sub without interfering with stock system?
dcfish Posted June 24, 2007 Posted June 24, 2007 Can I add amp and sub without interfering with stock system? Search these forums first Welcome to the club B)
t_diesel85 Posted June 25, 2007 Posted June 25, 2007 Can I add amp and sub without interfering with stock system? yeah you should be able to...the device to look for is called a line converter....you can get one at your local best buy, circuit city, or any car audio place. just tell them you want to hook up an amp to your factory stereo and they should be able to help you out.
nlexclusives Posted June 25, 2007 Author Posted June 25, 2007 Can I add amp and sub without interfering with stock system? yeah you should be able to...the device to look for is called a line converter....you can get one at your local best buy, circuit city, or any car audio place. just tell them you want to hook up an amp to your factory stereo and they should be able to help you out. thanks
