s_m Posted June 23, 2007 Share Posted June 23, 2007 Hey folks! I have a question regarding a front-end vibration that I am experiencing. Some quick background info: 1) 2006 GS300 - 17,000 miles 2) Vibration first started at about 10,000 miles. The vibration only occurs briefly when I let off of the gas between 70-75 MPH. Vechicle is smooth as glass when I keep gentle pressure on gas at that speed. 3) Replaced original Dunlop's (those tires were terrible) with Michelin Pilot Exalto's at 15,000 miles. Had front end re-aligned and tires road force balanced at time. Vibration would still occur when I let off of the gas between 70-75 MPH. No vibration if I maintained that speed. 4) Had front end re-aligned and tires road force balanced again. Same result. 5) Took vehicle to local Lexus service shop to diagnose. They are claiming it is the tires (feathering/cupping on inside of tires). I can't feel or see what they are talking about. Does this seem legit? I just find it hard to believe that two uniques sets of tires can show the exact symptoms, especially with the newer Michellin's after driving out of the tire shop. Any suggestions? Quote Link to comment Share on other sites More sharing options...
motocopter Posted June 24, 2007 Share Posted June 24, 2007 Any history of hitting a curb, pot-hole or debris by you or any other driver? With 17k miles, I wouldn't suspect worn components. Also, did you get the steering repair? I'm still sitting on a recall notice and not totally sure of the details. Quote Link to comment Share on other sites More sharing options...
DArustik Posted June 27, 2007 Share Posted June 27, 2007 Hey folks!I have a question regarding a front-end vibration that I am experiencing. Some quick background info: 1) 2006 GS300 - 17,000 miles 2) Vibration first started at about 10,000 miles. The vibration only occurs briefly when I let off of the gas between 70-75 MPH. Vechicle is smooth as glass when I keep gentle pressure on gas at that speed. 3) Replaced original Dunlop's (those tires were terrible) with Michelin Pilot Exalto's at 15,000 miles. Had front end re-aligned and tires road force balanced at time. Vibration would still occur when I let off of the gas between 70-75 MPH. No vibration if I maintained that speed. 4) Had front end re-aligned and tires road force balanced again. Same result. 5) Took vehicle to local Lexus service shop to diagnose. They are claiming it is the tires (feathering/cupping on inside of tires). I can't feel or see what they are talking about. Does this seem legit? I just find it hard to believe that two uniques sets of tires can show the exact symptoms, especially with the newer Michellin's after driving out of the tire shop. Any suggestions? I let a buddy of mine drive my GS. Little did I know he hit the curb once he returned my car. Ever since then I had these vibrations. If the vibration is occurring when the gas is released it has to be something in the front wheels. I'd get the front wheels checked out because one of mine was bent. If you pay around $60, a shop could straighten out your wheels. Hope that helps. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted June 28, 2007 Share Posted June 28, 2007 SOunds like worn bushings ,shocks or out of round tires. Start by increasing your tire pressure 5 psi Quote Link to comment Share on other sites More sharing options...
s_m Posted June 29, 2007 Author Share Posted June 29, 2007 Thanks to everyone for the suggestions. DArustik was right. I had a slightly bent wheel. It has been repaired - all is well now. Thanks! Quote Link to comment Share on other sites More sharing options...
