cheesewizer Posted June 18, 2007 Share Posted June 18, 2007 The cover on the gas tank is normally opened by pulling up on the lever in the footwell (to the left & rear of the floormat). When I pull on the lever, the door no longer opens. Hoping that someone else has been through this? Quote Link to comment Share on other sites More sharing options...
NewEnglandLexus Posted June 21, 2007 Share Posted June 21, 2007 Not with my Lexus, but with our Volvo same thing happened. There is a cable running from the cap release to the gas cap (may be more than one cable connected lengthwise). Try to follow the path; if you can order the part and do it yourself, otherwise any dealer should be able to do and should cost under $100 (cheap for a Lexus dealer). Quote Link to comment Share on other sites More sharing options...
