Squeaky Brakes After Changed!
I recently put new pads all the way around my ES with factory pads. Ran normal at first, then about 1 month later I get a really high pitches squeeeeek when I slowly come to a stop <10mph. If i'm hauling &#33;Removed&#33; and stop quickly, I notice no noise. I am pretty sure I put the shims back in exactly the same place I took them off but still cant figure out the squeak. Can anybody help?
Thx,
Snes
what kind of pads did you use? Toyota/Lexus OEM or another brand?
Ceramic or semi-metallic?
semi-metallic will make noise like that.
steviej
I bought them from Toyota and they came in the Toyota box. They were green in the back, and I think black in the front. Part# 04465-33060 for the front. The noise seems to only come at very very low mph, like when I am parking and seems to be coming from the front.
My toyo/lex pads had a blue backing, but no matter.
When you put them on, in addition to the shims did you use Brake Quiet or some other type noise reducing goop?
steviej
steviej
Nope, should I redo them?
