Greetings, I current have these rims on my 2004 Lexus LS430 (but NOT chromed, this is just for illustration) - they were apparently used from 2002 to 2005:
But I want to throw these on to be my summer rims (the original ones are a little scratched up so I want to use them for winters), these were apparently issued by Lexus from 2001 to 2004:
Is this going to cause me problems with the TPMS system (the little pressure sensors) because they are from 2001?
I have discovered that the LS430 from 2004 to 2006 used an "indirect" system, which I believe means there were no sensors directly in the rims/tires themselves, check out this table. Apparently, the LS430 has always used this indirect system, which apparently calculates it by using the ABS/VSC system.
Your rims were used from 04-06, the rims you showed were used from 01-04 as an option with 16inch standard rims.
Oh, you mean that the second picture I showed above were the 17" upgrade to the 16" standard size from 2001 to 2004?
Yep, they had one 16 inch design in 01, and then a different 16 inch design from 02-03. In 04 they came out with the wheels you have as standard after the refresh with 18s as optional.
