Dvd-bypass Modification: Please Confirm The Points In This Summary Are
I have a 2007 GS450h and am about to embark on doing the DVD-override modification. To those knowledgeable about such things, please confirm that the following points are all accurate:
:) The "DVD-bypass" modification (which involves opening the dash and cutting/splicing wires) will allow the following which are currently disabled while the car is in motion:
- watching DVD movies while in motion
- dialing of phone numbers from the touch screen
- viewing (and selecting) of playlists on mp3 DVDs or iPod (with the vaistech adapter, which I have installed)
- viewing detailed mp3/ipod track information (artist, song, genre, etc). (I actually want this MUCH more than the movie or phone capabilities)
:) The DVD-bypass does not allow for navigation destination entry while in motion. For this you need to create a 6.1/5.1 "hybrid" disc (which I have done and works great)
:) In terms of the actual process, once I remove the Navigation unit (as described in detail elsewhere):
- there will be three white harness plugs attached to the back of the touch screen monitor
On the LEFT-most plug (closest to the DRIVER):
==> cut PURPLE wire
==> the end still attached to the monitor side is left disconnected and "capped off"
==> cut YELLOW wire
==> the end coming from the "car" is left disconnected and "capped off"
==> the end still attached to the monitor side is attached to ground (by adding a ring terminal with an extra length of wire)
On the CENTER plug:
==> cut the WHITE-with-SILVER-dots wire
==> the end still attached to the monitor is left disconnected and "capped off"
THEN, the car side of the PURPLE wire is <=spliced=> to the car side of the WHITE-with-SILVER-dots wire.
:) Posts that describe putting a physical switch in pertain to inputting Navigation destinations while in motion and are separate from the above procedure.
I have printed out over 100 pages of forum posts on this topic, so I have done my best to research this. Just wanted a few things confirmed before I start snipping wires in my $60K+ automobile. Thanks!
Choose a wire with enough slack that it can be spliced/soldered, should you make a mistake.
Tom
Did you mean to say "Cut a wire with enough slack that it can be spliced/soldered, should you make a mistake."?
I don't think one has the option to choose among wires to cut.
