marvelusjd Posted May 27, 2007 Share Posted May 27, 2007 I tried to start my IS250 this evening, and the engine start button had the green light on and won't start. I've tried everything in the manual and nothing has worked. Anyone else have this problem or suggestions on how to fix it? Quote Link to comment Share on other sites More sharing options...
bartkat Posted May 27, 2007 Share Posted May 27, 2007 I tried to start my IS250 this evening, and the engine start button had the green light on and won't start. I've tried everything in the manual and nothing has worked. Anyone else have this problem or suggestions on how to fix it? Try it with your other keyfob or hold your keyfob right next to the start button and try it. If that works, then your key battery is dead. Quote Link to comment Share on other sites More sharing options...
bartkat Posted May 27, 2007 Share Posted May 27, 2007 Any luck yet? Quote Link to comment Share on other sites More sharing options...
marvelusjd Posted May 27, 2007 Author Share Posted May 27, 2007 Any luck yet? I put the key right next to the starter, tried to start it, and nothing... Quote Link to comment Share on other sites More sharing options...
marvelusjd Posted May 27, 2007 Author Share Posted May 27, 2007 Any luck yet? Thanks for the quick response. I put the key right next to the starter, tried to start it, and nothing... Quote Link to comment Share on other sites More sharing options...
bartkat Posted May 27, 2007 Share Posted May 27, 2007 Neutral switch for park or brake pedal switch may not be engaging. Might try moving the shifter back and forth a few times and/or pushing the brake pedal a few times while pushing the start button. Only thing else I can think of right now is a dead car battery. Quote Link to comment Share on other sites More sharing options...
marvelusjd Posted May 27, 2007 Author Share Posted May 27, 2007 Neutral switch for park or brake pedal switch may not be engaging. Might try moving the shifter back and forth a few times and/or pushing the brake pedal a few times while pushing the start button.Only thing else I can think of right now is a dead car battery. Looks like the battery was dead. Jump started and all is well. Thanks! Quote Link to comment Share on other sites More sharing options...
