PapachristosJ Posted May 22, 2007 Share Posted May 22, 2007 since the past week my front left wheel keeps making this squealing noise which is really bothering me. Idk what the problem is, my friend told me it's either the bearing or the brake caliper rubbing against something, b/c it doesnt squeal when I use the brakes. PLEASE HELP!! thank you.. Quote Link to comment Share on other sites More sharing options...
Grumpa72 Posted May 22, 2007 Share Posted May 22, 2007 If very light pressure on the brake pedal causes the squeeling to go away, then this is an indicator that your pads have worn to the point that the brake wear indicators are hitting the rotor and making the noise that they are designed to do. I would pull the wheel off and check out the pads. This is an easy DIY job and I would do it sooner than later. Quote Link to comment Share on other sites More sharing options...
PapachristosJ Posted May 22, 2007 Author Share Posted May 22, 2007 k thanks will do Quote Link to comment Share on other sites More sharing options...
