Automatic Transmision Fluid Replacement
According to Lex 2001 gs430 svc. man. it dry fill is 9.4qts but drain and refill is 1.9qts. I want to change the ATF fluid, as I'm doing a 60K miles maintenance. What is the sense if only draining 2 of 9 qts? What is correct way to REPLACE fluid?
TIA....
