Interior Light Bulbs
ac7228
Has anyone replaced the interior light bulbs with white bulbs?
I was thinking of replacing the door courtesy lights, the map/dome lights, the glove box light, and the lights in the footwells.
Any link or recommendation as to what bulbs to use would be greatly appreciated.
Thanks!
ac7228, This is a good site for LED lights. I have the WLED-x6 LED Wedge Base Bulbs in the door, license plate, trunk, park lights and amber color in the side markers. http://www.superbrightleds.com/mini-wedge.html
I have the Festoon Base Bulb in the interior cabin fixture. http://www.superbrightleds.com/festoon.html
The site has upgraded since my last purchase in 2005, they have stronger bulbs (brighter lighting) to select.
What bulb did you use for the lights in the footwell?
Which size festoon did you use for the interior cabin fixture?
The bulbs haven't given you any problems on your SC430 and totally compatible? Is there a certain wattage for the different bulbs?
Thanks!
ac7228, I own a Sc400 and the part number for the footwell is 168/194. I used the WLED-x6 LED wedge base bulbs. The part number for the interior cabin fixture is 3022. I used the 3022-x4 LED Festoon bulb. I haven't any problems with the LED bulbs. Use the site below to determine the Sc430 part numbers for bulbs.
http://www.sylvania.com/ConsumerProducts/A...placementGuide/
