slinzy Posted April 26, 2007 Share Posted April 26, 2007 Some of my dash/cluster lights work great! Some flicker...and then some aren't working at all. Is this a simple fix meaning pull the dash and replace bulbs? Quote Link to comment Share on other sites More sharing options...
coolbum_sc400 Posted April 27, 2007 Share Posted April 27, 2007 Some of my dash/cluster lights work great! Some flicker...and then some aren't working at all. Is this a simple fix meaning pull the dash and replace bulbs? i have the same problem on my 93' sc400 the speedo and fuel tacks dont work at all and the rpm tack flickers in some area's i turned my brightness down and now it doesnt flicker and from what i have read on this its not an easy fix by just replacing blubs. Quote Link to comment Share on other sites More sharing options...
pingpong Posted April 27, 2007 Share Posted April 27, 2007 its an easy fix if you have the stuff. reason why your lights died is cuz the LED inside are burnt. they sell kits. search google. Quote Link to comment Share on other sites More sharing options...
jsi4u2nv Posted April 30, 2007 Share Posted April 30, 2007 the lights on the gauge cluster can be replaced but the needles work on a l.e.d. source and need to be fixed. There are someplaces that refurbish your cluster for about $300 or less but you would have to remove the cluster, mail it to them then wait a week or two for the cluster to be returned to you. If you are mechanically enclined you can remove the cluster, take it apart, replace the burned out bulbs, and just use some bright red hobby paint for the needle tips... might be a ghetto fix but at least you can see where the needles are pointing. Quote Link to comment Share on other sites More sharing options...
