brdplya1 Posted August 25, 2003 Share Posted August 25, 2003 my cruise control doesn't work after getting repairs done to replace cam seals and valve cover gasket. The car RPM's ramp up about evry 2-3 minutes. It acts like it going to resume cruise control, then goes back to regular speed and this is without cruise control activated. Any ideas? Quote Link to comment Share on other sites More sharing options...
hammo400 Posted November 26, 2003 Share Posted November 26, 2003 Hi Playa! I don't know if th repair was a direct cause of the malfunction with your CC, but here are a couple of other things to check that may lead to another source for the problem: Does the CC light come on on your dashbaord? iS YOUR AIRBAG LIGHT ON? iS YOUR horn working? If you answered N/Y/N to the above, you'll need to replace the "spiral cable" within the steering wheel - $300.00. The above 3 happened one-after-the-other for me with the CC intermittently going on/off first. It may also be a fuse. Look in your Owner's manual to find which fuse is for the CC and check it . Quote Link to comment Share on other sites More sharing options...
Meist21 Posted November 27, 2003 Share Posted November 27, 2003 Definately check the fuse. I have heard (with these cars) that many times this is the problem. Many people do not realize this until they have spent big bucks on other parts first. Quote Link to comment Share on other sites More sharing options...
