Jos. Posted December 2, 2010 Share Posted December 2, 2010 Finally got the nerve to pull my headliner down using the tutorial (lexus wanted $235 to repair sunroof leak), once i removed the paneling in the rear behind drivers seat found the plastic tubing disconnected from the sunroof drain........placed this line back on and pulled car outside during heavy Texas rains this weekend and PRESTO.....no leak in headliner or trunk.............saved myself $235........FELLAS......THESE TUTORIALS ARE "OFF DA CHAIN"..............92 ls 400 FYI. There is a proposed class action for this very common leak problem. For information contact me at jsantoli@santolilaw.com or call 1-800-279-6996. Jos. Santoli, Esq. Quote Link to comment Share on other sites More sharing options...
ls400305 Posted March 21, 2011 Share Posted March 21, 2011 i have the same problem my sunroof leaks in the front driver side and rear driver side also didnt know to fix it is been leaking for about 3 to 4 months and now my seat are bad because of the water. i took off my headliner but didnt see anything wrong or missing in the sunroof. Quote Link to comment Share on other sites More sharing options...
RonRiv Posted June 12, 2011 Share Posted June 12, 2011 where's the sunroof headliner tutorial?? i searched everywhere. my roof leaks... help. click here -- sun roof <<--- Popped the drain tubes out of the drain holes on each side of the trunk (drivers side is directly under antenna on 95 LS 400.. did the weedeater string, but solved blockage by just blowing in the tube.. yep.. nothing high tech, I just cleaned the end of the tube, put in in my mouth and blew.. I could hear it clear out something and then I tested by closing trunk, and running water onto the sunroof.. both tubes were draining just fine!! Fixed! Quote Link to comment Share on other sites More sharing options...
Elliot08 Posted July 17 Share Posted July 17 If I get in my car and my floors wet is this most likely the same situation? My rear passenger floor is SOAKED Quote Link to comment Share on other sites More sharing options...
