98 Gs Suspension Sqeaks
Hey, guys. My front suspension squeaks when I go over bumps in the road, speed bumps, etc. Definitely happens more when it is cold outside. It does not happen when I turn, accelerate or break.
I also started noticing it after I dropped it with l-tuned springs and shocks/struts.
Help!
Help!
does it squeak in the front?
if so what happens is when you recently lowered the car the this of course affected the ride hieght and the way the lower arm sits thus adding a stress on the now old lower ball joints and so when you move over a bump or stop and accelerate this ball joint squeaks like no other.
i had the same problem lowered on ltuned struts and springs had to replace both ball joints not to expensive(depending on what you consider expensive) its like 80 bucks for the joint just have to have them repressed its the labor that will whack you.
took out the old sus and installed coilovers because for some strange reason the ltuned struts blew out after a year. so just a heads up
hope that helps i know that sound is embarrassing
good luck sorry for no punctuation i really dont know how to make sentences...haha
