Is There A Failsafe On The Drivers Seat Position?
crane
Hi all, new member.........but I have done my research first.
The problem I have on my 1991 ls400 is as follows:
Drivers seat will not move......
The passenger seat is fine, the steering column and mirrors all move fine as does the belt adjutment.
The drivers seat lumber works fine
whenever you press the adjustment buttons you get a click from the seat ecu.
the memory buttons move all but the seat
there is power to the seat and I have replaced the ecu.
Is there somthing that needs pushing or pulling to make it work?
Any advice appreciated
Check the motor that moves the seat. It seems likely it is the defective part, since you've replaced the ECU, and you say the seat switch triggers the relay.
/Alexander
I have changed the motor, hence I am wondering is there a sequence to operation (does the ignition need to be on or the handbrake on etc).
The relay within the ecu is clicking.
The story is that the ignition wires were cut and all joined together, I have now seperated them and correctly (I believe) reconnected them but no joy.
I would think iif it were another faulty motor one of the other seat functions would work.....e.g. recline.
The lumbar function is wired independently from the other functions!
ignition wires were cut and joined together, in Cambridge..... :whistles:
what kind of car you got there man?
ignition wires were cut and joined together, in Cambridge.....:whistles:
[/quote
:D ....nah, cut as the previous owner wanted a keyless ignition and remote lock/start!!
