On my wife's '91 LS there is an intermittent problem with 4 of the warning lights in the dash display. They are the coolant level, oil level, battery and another I can't recall right now but... At any time while driving, these lights can come on all together and if the cruise is engaged, it will disengage it. Any thoughts?
thanks
Mark
I do not think it is the alternator. I suspect that when you are turning on the key that the ignition switch is not being moved to exactly the right position. Sometimes if the key is just a little off wierd things can happen.
