Cabin Air Filter
  • 4 months later...
I removed the carpet on the right side of the gas pedal like the direction said, but there is not heater unit or filter there. I also checked under the glove box and I see the heater motor but I saw no filter. Does the 2000 ES300 have a fcabin filter?
removed the carpet on the right side of the gas pedal like the direction. you will see a plastic cover with two latchs. Remove the cover and slide out the filters (2) one on top of the other. the plastic cover is either white or gray in color. Take your time when searching for this cover. It's you first time, you will see it. Good hunting!
