Help a noob. What's the biggest you can go on a 2.5" drop and being able to effectively correct the camber? I've searched everywhere and am not really finding anything out. I am currently running 20"s, I love them but the tires a sooooo expensive and they do not last more then 6-7k. Any camber correction and I'm afraid I would get some rubbing. Thanks in advance.
How much clearance did you really gain from it? I need some extra room for some camber adjustment. Also, did you have a body shop do it? Did your paint crack at all?
I gained about an additional 3/4" of sidewall clearance. I'm not sure how the wheel liners in your car is set-up, but you might have to cut or remove the liners to roll for fenders flat.
I rolled the fenders myself, with a baseball bat and a heat gun. Just make sure that the paint is properly heated, before rolling the fenders and it shouldn't crack.
I'm gonna give it a shot then. Got front and rear camber kits from TM Engineering, and I'm gonna roll the fenders to get the most out of it. Wish me luck!
