1993 Es300 Windshield Reservior
Fedesnatr
Im looking for a new reservior for my es300. Anyone know the best place to order one from? Also, is the 93 ES300 the same as a 93 Camry? I can find all kinds of parts for the Camry and I wanted to know if they were interchangable! Thanks for your help!
$110 for a plastic bottle.....geeez! :whistles:
not just any plastic bottle. It is made from the finest polypropylene and designed by some very hard working computers. The bottle is custom fit for perfect placement under the hood. :geek:
On the other hand. I hear ya Alan, it's a wicked ripoff.
steviej
well i found one for a 93 toyota camry on ebay for much less. will that fit, since the camry and the es 300 are the same in so many ways?
Can't help you there. Find a 93 Camry in a used car lot and have a look under the hood.
I may or it may not be the same shape. It all depends on what else is under the hood in that area. If the ES has ABS and the Camry does not, then the whole traction control module is right by the washer jug and the jug sits low in the fender with a long neck coming up past the ABS/TC pump.
steviej
