Headlight Relays
Hefavitzen
Do you guys know of a place to get the relays other than the dealer? Also, to make sure, are the relays that control the high beams located in the pod that is actually attached at the radiator? Has a black, and 2 burgundy relays plus 1 fuse?
My friend with a 2004 RX300 has a situation where her low beams work, but her high beams do not. The inside (toward the radiator) lights work on both High and Low beams, but the outer lights do not work.
Thanks! Jeff
