2000 Lx-470 Clock Spring & Din Opening Question
Captainrye
Does anyone have the part number for a 2000 LX Clock Spring...and do you know if it is the same part as a 2000 Land Cruiser? (I've found that the Toyo dealer is a little more reasonable than my Lexus shop. Pulled mine out...found the split (Horn, Cruise not working & airbag light on) and actually tried to solder the ribbon cable back together to no avail...just too small an item for an untalented solderer.
Question 2- Can a standard double-din nav system fit in our openings? For instance...a Pioneer AVIC-Z1? Thanks folks!!
