MikeMiel Posted January 28, 2007 Share Posted January 28, 2007 The power mirrors do not work on my sc400. The thing is is that neither one doesn't work, so if both don't work, it needs to be an electrical thing, not something in the gears or locked up somewhere. I checked the fuse, their fine. Is there anything else I should check? Thank You in advance. Quote Link to comment Share on other sites More sharing options...
DomLee Posted January 29, 2007 Share Posted January 29, 2007 Check the plug which is underneath the mirror control panel in the driver's side arm rest. It's pretty easy to pop out...just a small screwdriver will do the trick. Once the panel is popped out, look at the plug. Quote Link to comment Share on other sites More sharing options...
aliga Posted January 30, 2007 Share Posted January 30, 2007 Check the plug which is underneath the mirror control panel in the driver's side arm rest. It's pretty easy to pop out...just a small screwdriver will do the trick. Once the panel is popped out, look at the plug. if that doesnt do it, it is your mirror ecu which is faulty. they go bad all the time. i have one for 40 shipped to your door. email is gazi.ali@gmail.com Quote Link to comment Share on other sites More sharing options...
MikeMiel Posted January 30, 2007 Author Share Posted January 30, 2007 Where is the mirror ecu located? How hard is it to get it replaced? How can I check if that is really the problem? Quote Link to comment Share on other sites More sharing options...
