Front Parking Light Replacement
Grumpa72
I put my parking lights on and the LF one does not work. I can see the connector at the back end of the light casing but I cannot get enough force with my finger tips to remove it. Any tips or hints on this? I assume that this is just the usual twist 90 degrees and pull out type of socket? This is an '05 330 and the bulb in question is at the top of the headlight cluster and shines down from the 12 o'clock position. It comes on when the parking lights are turned on.
Gary
Well, that was certainly an underwhelming response. The silence was deafening. :)
Since no one has EVER done this, I finally took a pair of long needle nose pliers and the offending light bulb socket came out with only a little bit of persuasion. It takes a #168 bulb btw.
Gary
