Courtesy Lights - Fuse? '91 Ls 400
ddmcginnis
Hi all, new member here ('91 LS 400) and have found some very helpful information. I am stumped by a problem with my front door courtesy lights, under dash lights and glove box light not operating (possibly light at ignition switch?). The back door courtesy lights work fine.
I am unsure which fuse operates these courtesy lights -- any help here? Bulbs are good, didn't have a multimeter to check voltage, but my guess is a fuse controls all these. Dome light works and that is the only relevant fuse I found......
Doug
well if the bulbs are good and the fuse is good then i can only guess the door switches have a loose connection. Take them out. Spray them with wd40 and you should be in business. Hope this helps.
