po2love Posted August 20, 2003 Share Posted August 20, 2003 How do you replace the door speakers? It's for a 93 ES300 Quote Link to comment Share on other sites More sharing options...
bbsal Posted August 21, 2003 Share Posted August 21, 2003 very easy.read alot of old posts because certin speakers dont sound good in the car.theres a screw inside the little cup type thing that you close the door with. just pop the plate up then unscrew that then pull off the door handle cover then just pull at the bottom of the door panel and it will pop open. then just lift up and out and it will come out once your at the speaker its a couple screws and its out.replace with 6 1/2 inch.no treble comes out of them so a woofer would be best.sort of like one that comes with a component set.i put infinity in mine and it sounds great along with new tweeters that came with the set.hope this helps Quote Link to comment Share on other sites More sharing options...
