douglasmiami Posted January 11, 2007 Share Posted January 11, 2007 Recently (I'm having a bad month with my car) my interior dome light has gone out (door-triggered light on interior roof of car behind driver right shoulder). Is this a bulb or a fuse issue? Ib bulb, can I open dome light to replace? Thanks. Doug Quote Link to comment Share on other sites More sharing options...
vj3 Posted January 25, 2007 Share Posted January 25, 2007 Recently (I'm having a bad month with my car) my interior dome light has gone out (door-triggered light on interior roof of car behind driver right shoulder). Is this a bulb or a fuse issue? Ib bulb, can I open dome light to replace? Thanks. Doug Changing the bulb is easy just pry open the plastic cover with a screw driver. (tape screw driver head so you won't scar the plastic) then change the bulb with the same new bulb . I doubt it's fuse issue, if it's a fuse issue it's not only your dome light that will not function, but any way just to be sure double check your dome fuse if it's busted or not.(refer to your manual-look for your FUSE BOX location) Quote Link to comment Share on other sites More sharing options...
