firer Posted January 8, 2007 Share Posted January 8, 2007 can someone tell me how to remove the inside d/s rear door trim in order to get to the window hardware. i went to lower the rear window and the glass fell all the way down. ive noticed its got several plastic panel/trim retainers all around the door trim but i cant seem to remove them without breaking the retainers themselves. is there a trick to removing these plastic retainers. thanks in advance, rey Quote Link to comment Share on other sites More sharing options...
SKperformance Posted January 9, 2007 Share Posted January 9, 2007 pull up the carpet in the handle and there is a screw under it. Quote Link to comment Share on other sites More sharing options...
firer Posted January 9, 2007 Author Share Posted January 9, 2007 pull up the carpet in the handle and there is a screw under it. thanks sk, but the problem im having is removing the plastic panel/trim retainers all around the door trim panel. when i try to pry and pull them out they are breaking. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted January 10, 2007 Share Posted January 10, 2007 They are old and need to be replaced not a big problem and easily replace. Quote Link to comment Share on other sites More sharing options...
firer Posted January 10, 2007 Author Share Posted January 10, 2007 They are old and need to be replaced not a big problem and easily replace. thanks sk, i will let you know how i fair. by any chance do you know were i can get d/s rear window regulator without having to buy the motor. the dealer is charging $504.00 for the regulator and motor. they wont sell them seperately. Quote Link to comment Share on other sites More sharing options...
