Has anyone noticed when starting off driving in cold weather the engine sounds like a diesel?? a rattle rattle sound for about a minute then goes away... I started when the temp was around 40 deg..
My IS350 has 12,000 miles on it
I drove my IS350 on Friday with an outside temperature range of 25 to 38 degrees F. The engine was very quite.
Regards,
Chris
Regards,
Chris
Thanks... I may have a problem !!! George
I haven't heard any engine noises other than the normal clicking from the high pressure fuel pump/direct injector system as discussed in other threads.
