my car the antenna cable breaks off in the power unit and will not allow the replacement mast to be pulled in all the way. Is anyone had this problem before please help me with instruction how to remove the power antenna assembly from the car and disassemble the drum assembly and manually remove the broken portion. Your help very appreciated. Thanks
I've done this and posted on it with a fairly detailed account of my experiences, check out the following links and I believe I gave part numbers for replacement parts as well. If you run into questions please post and I'll certainly help all I can
Post #7 on the first link is my account of replacing the antenna
http://us.lexusownersclub.com/forums/index...c=29014&hl=
http://us.lexusownersclub.com/forums/index...c=28874&hl=
thanks to jgr7 & tmastres, these links are very helful. Your info. very easy to followed and did replaced in 2 hrs. Now my car antenna working up and down. I like it very much. Thanks again.
Glad you got it fixed, thats what this forum is all about, glad I could help too.
