eddieooo Posted December 4, 2006 Share Posted December 4, 2006 Since no one uses the back seats of a 430sc, those rear head rests only reduce the visibility out the back window.....Can these be removed without ruining anything? Eddie Quote Link to comment Share on other sites More sharing options...
SKperformance Posted December 4, 2006 Share Posted December 4, 2006 The rear headrest are also part of the roll over saftey cage. Removign them can induce a new damage point. Quote Link to comment Share on other sites More sharing options...
DirtySC430 Posted December 6, 2006 Share Posted December 6, 2006 I always wondered the same thing... But if they are a rollover issue, that only applies when the top is down, I believe. And if you roll over with the top down, you certainly have worse problems to contend with. Has anyone taken the headrests out? Quote Link to comment Share on other sites More sharing options...
Sled Driver Posted July 31, 2007 Share Posted July 31, 2007 I always wondered the same thing...But if they are a rollover issue, that only applies when the top is down, I believe. And if you roll over with the top down, you certainly have worse problems to contend with. Has anyone taken the headrests out? Under each headrest is a welded tubular roll hoop. So while you may remove the headrest, the hoop remains. It would look like !Removed! Quote Link to comment Share on other sites More sharing options...
