Radiator Help
gp1200x
I wanted to replace my radiator and ran into trouble. (Ordered a replacement a few years ago due to a leak which I fixed but decided to finally put it in....not easy to do!).
Anyway the replacement one is also almost identical in size, dual row, but it does not appear to have a thread hole for the coolant sensor which is fairly large??
I have a 99 RX300, probably one of the early models since I had most of the defects...no tranny problems so far - 108K.
Were there difference placements for the coolant sensors or did this manufacturer screw up the design?
If need by I will buy another radiator...I like the stock type with plastic top and aluminum body, which my replacement is not composed off...it appears to be like the old tin types.
Thanks
