Fuel Leak At Engine
Paul Sherman
Hi all, I have a '93 LS400 with 194K on it.
I started noticing an occaisional slight gas smell when I first got in
the car, which disappeared as in a couple of seconds after starting it.
Today, I was finally able to track it down - There's a small leak
at the top of the engine; driver's side, toward the back. If I
were to guess, it looks like where the fuel line goes into the
injector rail. It's currently just a bit of dampness, no pooling,
but it won't get better by itself.
Since the nearest dealer is 45 minutes in the opposite direction
from where I work (which means I can't even get there before
they close), and I can't find an independant Lexus mechanic in
St. Louis, this may be up to me and my regular mechanic to
figure out.
Has anyone seen this before? I searched the archives once, and
didn't find much, but will search again with different key words.
Since I'm driving across state in a week, I'd love to get 'er
fixed, rather than rent a car. OTOH, I've heard others mention that
Lexus dealers have provided loaners - would that happen with me?
If so, it may be worth taking some time off and run it up to them.
Any guidance is appreciated.
There are a couple of gaskets where the fuel line connects to the injector rail. Perhaps its as simple as a failing gasket.
As far as loaner vehicles, i think that's up to the discretion of each dealer. Some only provide for warranty or CPO vehicles.
Good luck.
Woo-Hoo! Found and fixed!
The fuel line is attached to the rail by a fuel damper.
That damper failed. It looks like it may have been going
for a while, but finally got bad enough to be noticeable.
Easy part to change, difficult and expensive to find ($130).
Dealer only item, no part # handy, 1st dealer didn't
have it. Also, it's been superseded by another part.
Two hours running around, 20 minutes labor to change.
