camlex Posted October 17, 2006 Share Posted October 17, 2006 Hello, I have some wired noise comes from front when I entering or exiting in driveway (shopping area, house). I have checked struts, mounts, Engine mounts, Lower arm control bushing, Ball joint, sway bar link, bushing etc. everything is in good shape. What could be wrong or what to check? Thanks, Quote Link to comment Share on other sites More sharing options...
that boy asad Posted October 17, 2006 Share Posted October 17, 2006 Hello, I have some wired noise comes from front when I entering or exiting in driveway (shopping area, house). I have checked struts, mounts, Engine mounts, Lower arm control bushing, Ball joint, sway bar link, bushing etc. everything is in good shape. What could be wrong or what to check? Thanks, check the undercover (air dam)... might be hanging? Quote Link to comment Share on other sites More sharing options...
eman_be_lexin Posted October 17, 2006 Share Posted October 17, 2006 CV Axle boot could be torn. Similar problem with my previous car. Do you hear the sound when making a sharp turn only? Quote Link to comment Share on other sites More sharing options...
camlex Posted October 17, 2006 Author Share Posted October 17, 2006 Thanks for quick reply. Air filter housing, check peice between TB and filter, everything looks tight. What is (air dam)... ?? Thanks, Quote Link to comment Share on other sites More sharing options...
camlex Posted October 17, 2006 Author Share Posted October 17, 2006 CV Axle boot could be torn. Similar problem with my previous car. Do you hear the sound when making a sharp turn only? That noise i knows, it's comes only when you takes turns. Thanks, Quote Link to comment Share on other sites More sharing options...
camlex Posted October 20, 2006 Author Share Posted October 20, 2006 Hello, Noise is still there. Today, i am going to remove cabin air filter. Driving me crazy. Please advise. Thanks, Quote Link to comment Share on other sites More sharing options...
camlex Posted October 21, 2006 Author Share Posted October 21, 2006 Hello, Before i remove cabin filter, i decided to roll down driverside window and try to hear the noise. Surprise!! No more popping noise. That means it comming from door when window is close. I needs help. How to open the door. Thanks, Quote Link to comment Share on other sites More sharing options...
