andrecat112 Posted October 8, 2006 Posted October 8, 2006 are there any modifications to be noted when installing the Whiteline BTR39 20mm Rear Sway Bar, even though its for a 98 camry?
Toysrme Posted October 8, 2006 Posted October 8, 2006 No. It's easier to do if you drop the exhaust pipe. Just be sure to change the end links & grease the bushings well, or it'll be squeaking very soon.
andrecat112 Posted October 9, 2006 Author Posted October 9, 2006 Toysrme, you mean to change the existing end links and bushings? im at a total lost of what i should do. should i take a chance and buy an end link kit and bushings at the local parts store?
Toysrme Posted October 9, 2006 Posted October 9, 2006 Yes, change the existing endlinks & bushings. There's near no change the end links that are on there are going to be very good at that age. I would use some poly bushings. Sorta defeates the purpose of upgrading the sway bar if you're just going to put rubber back on there.
anthonyiez Posted October 9, 2006 Posted October 9, 2006 i agree, i see no point in upgrading the bar and leaving the old links on.
andrecat112 Posted October 9, 2006 Author Posted October 9, 2006 are these the end links and bushings you guys are referring to? if so, are these any good? ebay what size end links and bushings do i need to buy?
andrecat112 Posted October 20, 2006 Author Posted October 20, 2006 i just received my whiteline sway (BTR39 - made for 98 camry) bar in the mail the other day and it came with only 20mm bushings. will these bushings work with the exisiting (bushing) brackets for the 98 es300? im currently looking for replacement endlinks. thanks
