I didn't notice it until I change the balance to left7 and fade to front7. Both the speaker and tweeter on the driver side have no sound coming out. :cries:
Is it because of a fuse blown out? Or both speakers blown? Or someting wrong with the factory headunit? Or cable loose?
Please help!
I would check the connection to the speaker. There is no fuse for speakers, but I guess it's possible it became disconnected.
If it's plugged in the speaker, then test the speaker. Get a battery (9V or 12V) and quickly tap the connections of the speaker. If it pops, then the speaker works, and must be a wiring issue.
I have more possibilities, but try these.
(It could be the output is bad at the head unit too, but we can test that later).
I didn't notice it until I change the balance to left7 and fade to front7. Both the speaker and tweeter on the driver side have no sound coming out.:cries:
Please help!
if you have factory navigation the sound comes from the navigation computer to the drivers door so there may be a problem with the computer.
Thanks.
It just comes and goes. I have no idea why.
Both speaker and tweer work fine when it is good. I suspect it's the cable or the head unit. B)
Is it hard to trace the cable?
Thanks.
you just need an volt meter to trace the wires. its more likely a crack in the circuit board that is causing that sort of in and out. you would need to inspect the circuit board to find a crack in a trracing.
