camlex Posted October 3, 2006 Share Posted October 3, 2006 Hello, Everytimes i push brakes it's make noise in rear ("Click"). By hand while car was cold, i did check, Bracket are fine and tight. calipers moves little and pads makes noise. How to fix this problem? Thanks, Quote Link to comment Share on other sites More sharing options...
anthonyiez Posted October 4, 2006 Share Posted October 4, 2006 assuming you are using a high quality pad and the rotors are not grooved real bad (looks like a record), change the caliper clips that the pads sit it. toyota calls this a fix kit, although i'm sure raybestos, wagner or carlson makes it. they would probably call it a hardware kit though. Quote Link to comment Share on other sites More sharing options...
