dfire9 Posted September 29, 2006 Share Posted September 29, 2006 Well the first time i got the light check it pulled the code P0125. I reset the light to see if it would come back and it did but then pulled code P1155 which i looked and thought to be O2 sensor near firewall bank 1 sensor 1. I replaced the sensor and the light and now it has come back again. Does anyone know what this could be? It is still pulling the code P1155. Do you think this is bad sensor or do you think it is something else and if so what could it be.Now i will say that the sensor i replaced it with is Bosch sensor and the connector did not match so i had to use old connector on the previous O2 sensor. Please reply and let me know what u think. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
anthonyiez Posted September 29, 2006 Share Posted September 29, 2006 since this is actually an air fuel ratio meter and not an oxygen sensor, plus considering you had to cut and splice connectors, i'd say pony up and buy the right part from a toyota/lexus dealer. i'll say it again, i never use any aftermarket a/f sensors or oxygen sensors for any make of car. just not worth the hassle. Quote Link to comment Share on other sites More sharing options...
