Micah Posted September 26, 2006 Share Posted September 26, 2006 Hi, I found a solution for my problem with the aux in, but it will require replacing my radio with a 1998 to 2000 model nakamichi head unit. The question is this: will a 1998-2000 nakamichi head unit plug into a 1996 sc400 with standard pioneer sound system in it? If so, I'll start searching for an updated radio head unit so that I can use the adapter that I found. Its a mp3car.com. Here's the link: car2pc-toy adapter This unit even has a usb port so that one could conceivably hook anything with a usb port on it and control it with the right programming skills. The problem is that I don't have a schematic of the 98 to 00 sc300 and 400 nakamichi plugs at the rear of the radio to compare to mine. Thanks for any help! Quote Link to comment Share on other sites More sharing options...
dcfish Posted September 26, 2006 Share Posted September 26, 2006 Hi, I found a solution for my problem with the aux in, but it will require replacing my radio with a 1998 to 2000 model nakamichi head unit. The question is this: will a 1998-2000 nakamichi head unit plug into a 1996 sc400 with standard pioneer sound system in it? If so, I'll start searching for an updated radio head unit so that I can use the adapter that I found. Its a mp3car.com. Here's the link: car2pc-toy adapter This unit even has a usb port so that one could conceivably hook anything with a usb port on it and control it with the right programming skills. The problem is that I don't have a schematic of the 98 to 00 sc300 and 400 nakamichi plugs at the rear of the radio to compare to mine. Thanks for any help! A nakamichi headunit will not plug into a pioneer system. Two different systems altogether. Quote Link to comment Share on other sites More sharing options...
Micah Posted September 27, 2006 Author Share Posted September 27, 2006 Darn, Does the nakamichi and the pioneer use the same cd changer? Quote Link to comment Share on other sites More sharing options...
