Swaybar Link Bolt Stripped!
vinny186
I'm in the process of removing my rear struts and where the swaybar link attaches to the strut you have to use an allen wrench to hold the bolt in place as you turn a nut. Well, the allen wrench can't grab because it's stripped. Any ideas?
use an easy-out. You will have to replace the bolt after that. Easy-outs can be found at sears and/or home depot. Or try banging the next largest size allen wrench into the hole, again, the bolt will have to be replaced.
steviej
steviej
problem with that, is the bolt "is" the stabilizer link.
are you replacing the link? if so use a cut-off tool to just cut the end of the link. if not, use a 3/8ths impact, while holding pressure in on the link.
don't feel bad this is pretty common on all cars that use this design.
  • 2 years later...
